Thread
Boat tail project based on a single wheel trailer...
07-20-2015, 08:17 PM
590
permalink
BamZipPow
T-100 Road Warrior
BZP T-100 (2010)
- '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3:
24
mpg (US)
BZP T-100 (2011)
Last 3:
23.66
mpg (US)
BZP T-100 (2009)
Last 3:
19.01
mpg (US)
BZP T-100 (2012)
Last 3:
25.45
mpg (US)
BZP T-100 (2013)
- '98 Toyota T-100 SR5
Last 3:
25.79
mpg (US)
BZP T-100 (2014)
Last 3:
23.18
mpg (US)
BZP T-100 (2015)
Last 3:
23.85
mpg (US)
BZP T-100 (2016)
Last 3:
17.62
mpg (US)
BZP T-100 (2017)
90 day:
20.78
mpg (US)
BZP T-100 (2018)
90 day:
20.19
mpg (US)
BZP T-100 (2019)
BZP T-100 (2020)
2012 Scion iQ
- '12 Scion iQ Base
Catastrophe!
Noticed the single wheel was contacting the Coroplast floor upon returning from the Missouri/Kansas trip. This photo is with no load in Dark Aero.
Upon further investigation, I found that the extended length of the spring housing added extra leverage to add stress to the 3/8" thick steel support plate which subsequently bent from the constant pounding.
I will have to pull the wheel assembly off and have it straightened and git some supports welded underneath the plate to give it more strength. I could also pull the original rubber puck out and have the air spring bag moved closer to the spindle and swap the rubber puck to the front. This means I could also have the extension cut down some, too.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead
(07-22-2015)
BamZipPow
View Public Profile
Send a private message to BamZipPow
Find More Posts by BamZipPow
