Can you tell me the size of the 3 inlet holes?
I want to use it in my 1.4TDCI Ford, if the outside temp. is above 30 degrees celsius i see a rise in fuel economy. If i could keep my inlet air temp. above 30 at all times i guess it would always be more economical.
First i thought it was due to the higher diesel temp. but now i'm using Forscan and i see the diesel temp is always between 50 and 70 degrees, not depending on outside temp. but on engine load.
So i would like to know the diametres, if they are to small the engine chokes. (had one from a vw polo but that was way to small)
Thanks in advance!
