Old 07-21-2015, 04:17 PM   #1 (permalink)
cts_casemod
Boost Converter for high voltage electric vehicles
This topic is meant for discussion of a high power boost converter for electric vehicle use.
Right now two instances are proposed:
Achieve power factor correction of an AC supply, with the intent to charge high voltage DC Battery packs at high power levels and with great efficiency. At a later stage I plan to ramify this to a power factor buck converter for 144V battery packs.
Boost a given battery voltage to allow 144-400V Battery packs to power standard 415VAC insdustrial motors, with Paul's 3 phase motor controller. Such motors typically require a DC-LINK voltage in excess of 600V, which requires a very large battery pack and reduces reliability.
Things to discuss:
  • Topology: Single phase, interleaved, continuous or discontinuous modes, frequency of operation
  • Semiconductors: IGBT, mosfet SIC diodes
  • Inductors: Anything suitable goes here!
  • Power Hardware: DC-LINK design, pre-charging, IGBT drivers
  • Software: related to microcontroller based devices
The Following User Says Thank You to cts_casemod For This Useful Post:
e*clipse (07-21-2015)
