Old 07-22-2015, 08:09 AM   #3 (permalink)
phyregod
!!ytinasnI
PhY-49 - '90 Honda CRX Si
Tire weight is something I'm clueless about. No one lists tire weight in their specs. Not that I've found, anyway..
The stock SI wheels weigh ~17lbs. The konigs are ~11lbs. That is 24 pounds of un-spuing weight saved. Which is huge. But it does me no good if I just replace that weight with rubber..
I don't have the konigs yet.. Could cancel the order as they are back ordered. Is there a better solution? Lighter/skinnier setup?
