Old 07-23-2015, 09:04 PM   #15 (permalink)
jtbo
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
About the only thing you will find with a carb that will work with out an accelerator pumps a chain saw.
Some 4-stroke scooters don't have accelerator pump, I guess design is adjusted to that.
I have one of such carb, it doesn't die when giving throttle, there just is not much happening, not even at WOT.
Slide in that is huge, but throat is much smaller than what slide is, it is like if they would of put twice too big slide to that carb.
When exploring world of cheap chinese scooters, there are no thing that is impossible, no matter how much against logic some design is, some of them has tested it and managed to sell who knows how much of that junk.
If there is a leak near accelerator pump, is it sure that it is not the shaft that goes to pump which is worn so that it leaks from there and then just run off to area of cover?
