the design is its built into the carb float bowl. its leaking when i pump the throttle even when its not running. and its leaking from the cover. i am going to give it one more try and replace the pump again and this time take the float bowl and clean the crap out of it. or maybe ill buy a new float bowl to see if maybe it cracked
