Old 07-27-2015, 07:15 PM   #18 (permalink)
freebeard
Thanks. It looks like they use the minimum width for the roll bar, that will reduce it's drag. Could it pass tech inspection if you zip-tie an airfoil to the back of the roll bar?
This is the best open front wheel I've seen. It has a narrow tire on a wide rim and a smooth cap that overhangs the rim so there is one continuous curve from the leading to the trailing edge. The inner face is also smoothed.
I see what they're doing with the endplate/cycle fender, mimicing F1 race cars. I think the rear part is more important. With a tall, narrow wheel a fender, instead of the 30s swoop your red fender shows would look more like this:
Then, just because I can, here's a picture of an electric racer from the UK.
Do this with a roll bar—Short nose and tall tires. Raise the pedals and move them forward so the seat can move forward. How much contact patch do you need for the corners?
orengomotors (07-28-2015)
