I'd think they'd be a good choice, they can be had around here dirt cheap with problems.
The engine is tucked in pretty good, so not the easiest thing to work on.
One with a 5-speed, perhaps a 4-cyl swap isn't so hard, would have to research which ones might mate up, chevy typically not bad in that regard.
You can fit a geo metro 3-cyl with a samuri rwd transmission, or the 4-cyl tracker engine and trans.
