Old 07-29-2015, 05:55 PM   #88 (permalink)
freebeard
The idea seems appealing, but I need convincing that there is some advantage.
'Tiny House' is an attempt to evade the authoritative oversight that 'trailers' are subject to. Similar with houses on old log trucks and houseboats. In fact the most flexible tiny house would be a trailerable houseboat.
I see I mentioned adventures in squashing tubing. 1/8" steel sheet lining a pocket in a 4x4 post isn't cutting it. The 4x4 is stiffer than the steel I was going to get, but the press needs a rigid female die.
With the product and a basalt fabric skin, I could do this:
A four-wheel trailer with a garage in the back for a motorcycle that docks and has an auxiliary bridge with joysticks?
Fat Charlie (07-30-2015)
