Old 07-30-2015, 03:44 AM   #8 (permalink)
NickelB NL
Focus - '05 Ford Focus tdci Futura
Here i have some pics of the car underside as is. You can see how i will attach the aluminium strip. I will drill some holes to put the bolts trough. You can clearly see the ssuspention sticking out. The rest is fairly flat in the middle. Up to the gas tank. So maybe i have to make a belly pan at that point in front of the rear axel. I think my exhaust will be the leading point on witch i can adust my diffuser. Will see if i can raise it up some.
ID:	18366   Click image for larger version
ID:	18367   Click image for larger version
ID:	18368   Click image for larger version
ID:	18369   Click image for larger version
The Following User Says Thank You to NickelB NL For This Useful Post:
aerohead (07-31-2015)
