With such a long commute and the Merc paid off and all, I can see why you would keep using it. Drive in comfort and safety, arrive fit. Don't compromise on that...!
Air up the tires, install an OBDII gauge, block a grill or two (while monitoring air intake and engine temp on your new OBDII gauge), swap city and license plate lights for LEDs if they aren't already, remove whatever heavy stuff you don't need. Easy stuff that will help some.
 lifetime FE over 0.17 Gmeter or 0.1 Mmile.
