Old 07-30-2015, 10:48 PM   #28 (permalink)
GreenHornet
GreenHornet's Avatar
I do not have these wheels and tires currently on a vehicle. If you are concerned about the offset just check what the Fit is and that should tell you if they will work on your CRX without modifications such as spacers. I believe the CRX has a 4 lug 4 X 100 bolt pattern which is the same as the Fit. So lug pattern should not be an issue.
