Old 07-31-2015, 01:53 AM   #37 (permalink)
92civicvx
Panda - '92 Honda Civic VX
90 day: 53.55 mpg (US)
Charles II - '05 Honda Accord EX-L
90 day: 27.6 mpg (US)
Fitrari - '07 Honda Fit Sport
90 day: 36.4 mpg (US)
Originally Posted by GotToyota View Post
So after doing a ton of reading today, I think I realized that I may have two PCV valves.
The previous owner put in a new "PCV valve" up top at the intake manifold, and I've been reading that normally this is just a black elbow that is a straight flow 90" piece and that the "actual" PCV valve is at the chamber box underneath the intake manifold.
I noticed his PCV valve replacement for the top one was a typical aftermarket replacement, and that the one at the chamber box appears to be original. I plan on ordering a genuine Honda one for the chamber box and fabbing up my own "straight flow" piece up top. Until then, does having two PCV valves (and one possible bad one) seem like a reason my idle will occasionally dip?
I found the same thing on my vx. Put a oem replacement at the breather box(mine was bad) and cut open the aftermarket elbow to remove the guts and reinstalled it. I didn't have a idle issue before this and I didn't feel any difference after. It's very possible it could be causing your issue if both aren't working properly.
LOW&SLOW
Build Thread:http://ecomodder.com/forum/showthrea...ild-31679.html
