Old 07-31-2015, 04:05 PM   #10 (permalink)
RustyLugNut
Simply because of how a diesel operates.
Originally Posted by TimV View Post
Can you explain why cilinder deactivation is not good?
I have a vgt turbo.
A diesel always operates at "full throttle" simply because it has none. Fuel control is how you moderate power production.
A spark ignited gasoline engine uses a throttle. This causes the pumping losses talked about in depth on this and other forums. Cylinder deactivation results in larger throttle opening and a decrease in the pumping losses. Diesels do not have this pumping loss to begin with.
The Following 2 Users Say Thank You to RustyLugNut For This Useful Post:
Daox (07-31-2015), UFO (08-04-2015)
