Old 07-31-2015, 07:11 PM   #12 (permalink)
RustyLugNut
Though an excellent idea . . .
Originally Posted by Baltothewolf View Post
Why not go veg conversion? If you can find a few local restaurants to donate the payback would be way, way faster due to free fuel! You would only have to run on diesel until the the veg gets up to temp (or install an electric heater inside the veg tank).
. . . he does have to make sure his injection pump is up to the task. Most modern common rail diesel systems run at far too high a pressure to accept even a small thickening of the fuel that results in a disastrous increase in rail pressure and immediate failure of the pump.
The Following User Says Thank You to RustyLugNut For This Useful Post:
seifrob (07-31-2015)
