Old 08-05-2015, 01:50 AM   #12 (permalink)
ncs
RockMagnet - '04 Subaru Impreza wagon WRX
90 day: 26.16 mpg (US)
The sg2 is a guess, and you just change a lot of parameters. For closed loop, the timing was changed. If you stay out of boost, you will likely see a legitimate improvement, but you might have adjust the sg2 again to match.
Once you hit enough boost to go into closed loop, results become pretty random. You'll still be better than before, but the gauge will read inaccurately, possibly in both directions depending on how you drive. Open loop comes on a lot earlier than naturally aspirated cars, which doesn't help the accuracy.
The stock map is very rich, so with either AP map, you've gained something, even if it doesn't show up on the SG2. You might get a pleasant surprise at the pump.
Kinda weird about the 8 psi. The old wrxs like mine have a wastegate pressure of 11 before the ecu can even do anything.
You really should learn to tune. These ecus are completely open at this point. It an be really entertaining to try out different approaches to making power. Also the off the shelf maps leave quite a bit on the table.
