Old 08-05-2015, 06:30 AM   #14 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by jedi_sol View Post
Since the SG2 is assuming the same stoic AF ratios regardless of the tune, what do you think might be causing the SG2 to read higher mpgs with the economy tune vs the stock tune?
Any suggestions on how to test the claim that the AP achieves higher mpg vs stock?
I seem to recall you having a MPGuino? While not perfect, that would give you a more meaningful result.
If you have more power, you're going to run at lower load (which SGII will read), so it will record slightly improved MPG. It doesn't take into account the tuners leaner AFRs, so you'll probably get a bigger gain than the SGII shows.
