Old 08-05-2015, 07:16 AM   #15 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by ncs View Post
The stock map is very rich, so with either AP map, you've gained something, even if it doesn't show up on the SG2. You might get a pleasant surprise at the pump.
Also the off the shelf maps leave quite a bit on the table.
Originally Posted by serialk11r View Post
At heavier load the AP map is definitely going to be way more fuel efficient. Factory maps are always super rich for cooling purposes.
I have a 2005 STi with Cobb AP. The Cobb maps are super rich too, so as not to pop any motors. I'm at stage 2 and my gas mileage is down from stock no matter what OTS map I use.
