Old 08-06-2015, 11:55 AM   #8 (permalink)
Mr. Pancake
Hybrid Pancake - '03 Honda Civic Hybrid
90 day: 56.01 mpg (US)
Originally Posted by imaudi5 View Post
Gotcha-
...In the VX, I could easily tell/feel when it was in lean burn, I can't tell on the HCH. Is there an aftermarket display/test light I can wire up to show me?...
Generally, when the instant mpg gauge is showing 80 or above you are in lean burn. That's another reason why you can probably get better mileage with this car, the instant mpg gauge. You should find that sometimes backing off the gas so you lose as little as one mph will result in higher mpg. For example, @ 55mph you might be getting 60 mpg and at 54 or 53 mph you might be getting closer to 75/80 mpg (not necessarily actual figures).
