If you want a unique car that'll probably be faster than any other FWD Impala SS, then go ahead and do it. Your first step should be figuring out how you're going to physically get power from the motor(s) to the rear wheels. Using the rear axle from another car and connecting the motor(s) to the differential is probably your best bet.
If you want the fastest V8 car for the money, you might be better off getting a RWD car. For $10k you can easily get a car that is faster than your car currently is, maybe even faster than it would be with the electric motors.
