Old 08-08-2015, 07:14 PM   #279 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update:
I install the new alternator but to do this you have to remove the drivers side engine mount. This is what I found.
So a new one cost $160.00 so what I did is what I've done in the past and repaired the mount with 3M 8609 windshield Urethane.
Out side curing.
So tomorrow I will install it, and get back to testing and tuning.
I have had great luck with this in the past. They make aftermarket Urethane mounts but I don't like the vibration they cause. This is a little more driver friendly.
Pressure Gradient Force
The Positive Side of the Number Line
