Old 08-09-2015, 09:02 PM   #4 (permalink)
oil pan 4
Here are the pics of the work.
My gas purge rig just bushings and 1/4 inch hose barbs. I set the maxstar to 70 amps, used less than 1cm of 316L 3/32 filler rod for each weld, electrode is a 1/16'' 2% thoriated tungsten.
The hydro test had no leaks.
This winter I will be leaving to work well before sun up.
ID:	18427   Click image for larger version
101Volts (12-18-2015)
