Old 08-10-2015, 05:18 PM   #7 (permalink)
oil pan 4
Its going to mounted pretty high up in the coolant system its going to be force circulated though the heater loop with my diesel's electric coolant pump.
At this power level I wouldn't try to thermo syphon it. Now if it were mounted differently and if this element was powered off 120 volt power maybe.
I will still have the the 2 passive/ traditional 600 watt block heaters installed.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
101Volts (12-18-2015), Daox (08-10-2015)
