My 37 Ford would produce 60 psi on cold oil cranking at 100 rpm, about 1/3 of a modern engine (cranking speed). It had a push button starter with a steering lock ignition key cylinder. I would use the crank only function to pre lube the engine when it sat for a week or more.
regards
mech
