Old 07-29-2008, 10:10 PM   #17 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hankinator -
Originally Posted by Hankinator View Post
My charger is a Shumacher Speed Charge WM-1200A. I think its a few revisions old by now. I got mine from my Dad...he likely got it at a yard sale........
Shumacher has a website.
Thanks, this looks like it's the once-lost now-found grand-child :
SC-1200A - 12/8/2 Amp Charger/Maintainer/Tester
This gives me a "spec" a and a general price-point to work from. Schumachers are all over ebay, so I can be patient for what I want.
.... virtual time passes ....
This information also helped me to Google this :
Solar Charge Controller | Batterystuff.com
A 12V 7 Amp Charge Controller protects your lead acid batteries from overcharge. This charge controller is to be used with any of the P3 or Sunlinq 12 and 25 watt 12V product line and can handle up to 100 Watts of Solar Power. Controller ships with SAE type input/output trailer plugs allowing direct connection to the solar system. The controller is designed to plug and play with the 5 piece accessory set that ship with the solar panel.
Wow, here's another charger :
Sunsei Solar Charge Controller | Batterystuff.com
I have an old Unisolar flexible panel, with specs close to this current model :
Code:
UniSolar  Rated   Rated   Rated   Open     Short    Dimensions
Model     Power   Voltage Current Circuit  Circuit  (inches)
          (Watts) (Vmp)   (Imp)   Voltage  Current
                                  (Voc)    (Isc)
USF-11    10.3     16.5   0.62    23.8     0.78     21.80x16.70
I am hoping that the "Sunlinq 12" mentioned above is a good match for my Unisolar :
Sunlinq 12Watt 12V Portable Power Pack
Code:
Sunlinq SL-12 :
Maximum current at STC* (mA)  = 800
Nominal Operating Voltage (V) = 12V
Typical Power (Watts) at STC* = 11
Maximum Power (Watts)         = 12
*Standard Test Conditions:
Irradiance level 1000W/m2,
spectrum AM 1.5 and cell temperature 25 şC
CarloSW2
American Solar Energy Society
