Old 08-13-2015, 01:11 AM   #10 (permalink)
Frank Lee
Perhaps you can research what past winners/top finishers used.
Failing that, I'd look for the tire with the slickest tread design and the lowest load rating, as that one will likely be thinner.
In any case, if you can do it, converting to tubeless would likely lower r.r.
