Old 08-14-2015, 12:02 AM   #55 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by skyking View Post
One method that I'd do for the fun of it is wood strips, like a cedar strip canoe.
Instead of removing the plywood formers, plan on cutting most of them away and leave a 2" bulkhead there. This does a couple of things. Now you can glue and fasten the strips to that for easier construction, use less formers, and it will be stronger. It also give you attachment points.
Originally Posted by greengeeker View Post
.........I'm not necessarily following your description of the construction of the aeroshell but the visualization of the "canoe method" paints a picture........
starting with step 6 will give you a real good visual of the formers.
Building A Cedar Strip Canoe
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
