Old 08-14-2015, 12:58 AM   #3 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Originally Posted by 2000mc View Post
I think I'd want to try to figure out what temp the thermostat is actually running, especially if the lack of heat at times is a new symptom since last test.
EDIT: Thermostat has 16k on it. Replaced in in jan 2014.
The downhill part of my commute I'm talking about is the stretch from 1600 ft to 244 ft. About 9 miles long. Speed limit is 45 so over most of it and I'm alternating between coasting in gear with engine in fuel cut and coasting in neutral (no EOC because I can't bump start for the life of me). By the time I'm on the second downhill grade, it is closer to 50 or 60F.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
