Old 08-14-2015, 08:40 AM   #4 (permalink)
RedDevil
90 day: 56.53 mpg (US)
I'm building a parallel high voltage hybrid pack for my Insight, and if that is either working well or failed so I can reuse the cells, I would like to replace the ailing 12V lead battery.
I would use a top balancing BMS, of course. But I would also add a big diode and a NTC regulated charge limiter; the colder, the lower the charging current would be.
Finally I would indeed place the battery as low as possible, preferably at the bottom of a deep watertight box to protect it from splashes and flooding, with terminals on the top of it (at the same level as the current battery top).
