Old 08-16-2015, 12:03 AM   #49 (permalink)
GotToyota
Installed the new ground kit today. This kit is quality. It includes replacement for negative battery terminal and ground, as well as the valve cover ground, transmission ground and an extra ground that goes from the negative battery terminal to an area of your choosing. I put the extra one at a back bracket on the transmission. I used the stock mounting points, using sandpaper to grind down to bare metal to ensure good contact. Here's some pics comparing the original stock grounds to the new ones:
And I also replaced the right lower motor mount, the original had tried to be "mended" by the previous owner.
The Following User Says Thank You to GotToyota For This Useful Post:
AbramWagner (08-16-2015)
