Old 08-17-2015, 08:51 AM   #4 (permalink)
Joggernot
Joggernot's Avatar
I pay the dollar
We have a new station with air that can be pre-set for your pressure. If you do it like their instructions you have plenty of time to fill the tires. Take off the caps before you put in your money; set the pressure; fill the tires. Done.
I just did this with the truck, which was making loud tire noise that normally wasn't there. Learned that the last shop that changed out the starter for me also lowered the tire pressure from 50 to 32 psi. Took $2 to fill back to 50 psi.
Don't get on me for not changing my own starter...I'm no longer able to do these simple things.
