Old 08-17-2015, 05:00 PM   #12 (permalink)
user removed
My dad gave me his old Sears compressor, and I consider it to be a necessary tool in any mans garage. I use it for inflating tires, removing lug nuts, painting, cleaning, nailing siding and roofing. It's so useful that I recently installed a hose reel so that I don't have to fuss with putting away tangled hose all the time.
Now that we're on the subject, how do I change the oil on this thing? Is it simply opening the lower bolt to drain, and filling from the upper bolt? What oil should I fill it with?
Looks right on the drain and fill, probably a splash feed with a little blade on the bottom of the con rod (dipper-slinger). For oil I'd check for recommendations but 20 or 30 weight would probably be fine,doesn't even need to be detergent.
regards
mech
redpoint5 (08-17-2015)
