Old 08-18-2015, 07:39 AM   #1 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.92 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 17.88 mpg (US)
From 5w30 to 10w40 + Lucas Oil Stabilizer = Rattling and knocking increased.
Dad's 2000 Dodge Caravan 3.0 Litre was rattling and knocking a little bit and using oil a bit excessively though not smoking out the tailpipe. Initially I was using a 5w30 and was topping off with 5w40 Diesel oil and also had a container of STP Oil Treatment in there. So, in attempt to make this rattling and knocking go away we thought to try thickening the oil. I tried finding a 5w40 within certain limits; didn't work. I could've used a Diesel oil and was concerned it would clean the engine too much and increase oil consumption even more, so I didn't use that. I could've used Mobil-1 0w40, it wasn't a High Mileage oil though. So we ended using Pennzoil Conventional High Mileage 10w40 and Lucas Oil Stabilizer; This made the engine go from knocking a little bit, to knocking a lot more. Even after letting the van stay on for over half an hour it still did it.
So, now I'm thinking about taking the oil I drained out of the crankcase and putting that back in. It still has at least 1,500 miles worth of use in it. We changed the filter at least.
Earlier, I changed Mom's van's oil from 5w30 or 10w30 & STP to Castrol Full Synthetic 0w20. The van wasn't rattling before and now I think the fuel economy went up.
EDIT: Somehow this noise stopped being so noisy today. It wasn't so clear in the first hour of the oil change though so take this with a grain of salt, would you?
