More oxygen means incomplete burn, more co means incomplete burn, more hydrocarbons means fuel in the exhaust. Running rich has destroyed your cat. I think you know the general problem, just need to diagnose why its running rich. The oxy sensor should be correcting it... unless it is sending bad data. Edit: i see you replaced that.
Any news on compression test? Are you burning oil? Is the timing in spec? Ignition coil? Idk...
Map sensor? Those are pretty typical for failing.
