Those won't be bright enough. You would need the 22 Watt LED's with the cooling fan instead of the heatsink. But then the cooling fan doesn't fit within the closing cap of many headlight housings. The area of the light source is also much greater than a halogen or HID so the beam pattern probably lacks focus.
I always want more light on all my vehicles. Not less.
