Old 08-20-2015, 05:00 PM   #109 (permalink)
fearone
Astra 1.7cdti - '03 Opel/Vauxhall Astra Eco4 cdti
Originally Posted by TimV View Post
Ok, I orderd the coolant heater, a switch, an 80A relay and a 60A fuse + holder
Total of 88,87€
And this is a good investmend!
I always have a long warm up time, even in summer!
@ 20 degrees Celcius air temps with full upper grill block: 20 minutes (16km) to go from 25 to 85 degrees Celcius coolant temps.
@ -5 degrees Celcius air temps with full upper grill block: 35 minutes (30 km) to go from 0 to 85 degrees Celcius coolant temps
Hopefully those 600W and aditional alternator load would help the warm up times.
Try only to use it down hills, in gear.
