Old 08-20-2015, 06:49 PM   #21 (permalink)
freebeard
Do you tighten down on the three tabs by gripping the whole assemble at it's base or the tip of the antenna through the hole in the top? (And how would that work with the weathervaning?)
Because it is normal to the antenna, not horizontal. If you could enclose the top, there's a bit of a shark-fin opportunity there.
