Originally Posted by Old Tele man
Because the engine's ECM controls everything in EFI systems, begin looking at the sensors providing "input" signals INTO the computer, such as wheel-sensor, manifold air density, catalyst hi & low, coolant temp, etc.
Do you have an OBD reader? Something to tell you what the ECM thinks is wrong and thus causing too rich A/F operation?
Yes and no. The ECU pretty much refuses to throw a code unless unplug something it can throw a code for, BUT I can watch live sensor data. See this thread:
http://ecomodder.com/forum/showthrea...age-27192.html
I attached a datalog of what the ECU is outputting.
I'm using CarTester8000StableEdition_English, going to file-> view and viewing the .ctr extracted from the attached zip file.
PM me if you just want me to send you a dropbox link to the program.
OBD-1 Serial Interface - Toyota Wiki
