Looking to finally address how to change a flat tire on the road in case it ever happens.
I'm gonna git this trailer jack fer $30 plus tax and build up an attachment point on the rear of Dark Aero so I just have to bolt the jack in place when I need to use it. Since it's all together as a complete unit, it should be easy to use and put away.
1500 lb. Capacity Dual Wheel Swing-Back Boat Trailer Jack
The jack will be stored inside of Dark Aero along with the spare tires.
I am looking at another attempt at a wheel pant fer the single wheel again since the support plate is beefed up. This version will be fully installed on the wheel frame instead of the partial setup I had previously. I might consider the belly pan fer the wheel housing again but according to the dirt flow modeling, I don't see where it could improve it that much.
