Old 08-22-2015, 08:47 PM   #6 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by UltArc View Post
For example, does the i8 need as low of a CD if the frontal area is much less? I am not saying THAT is the answer, rather saying I imagine there is another factor at work.
Actually, the i8 is Cd .26.
The i3 is a bit narrower than a 3-series, but taller. CdA for the i3 works out to .69 m^2, but .64 m^2 for the 328i. The i3 with range extender is even worse, at .71 m^2 (presumably from cooling for the gas engine).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
