Originally Posted by pgfpro
My plans are to go through everything and eventually do a rear mount turbo, that will have a generator/motor on the turbine side. I also want to incorporate waste solvent fuel like I did on my Talon. I'm not going to mess with the computer for now.
I'm also going to purchase a extra engine to dissect and see what improvements can be made?
Unless it's REALLY cheap to get an engine, I wouldn't get a spare. The best you can do is probably raise compression ratio, then keep a jug of E85 on you as anti-knock additive.
Also a rear mount turbine generator would be ineffective for increasing efficiency, you want it before the cat. You probably want to modify the turbine housing for reduced backpressure.
An easier way to collect waste energy from the exhaust would be this:
http://www.alphabetenergy.com/product/powermodule/
If you use that AND a turbine, you'd be looking at some ridiculously high thermal efficiency though.
