Old 08-23-2015, 03:24 PM   #32 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Originally Posted by ksa8907 View Post
I see you have have never cleaned the intake or injectors. At the minimum i would recommend buying a bottle of chevron injector cleaner. If you feel ambitious, remove the intake manifold and clean with a toothbrush and carb cleaner, or take a shortcut and just to the throttle body.
I'm waiting on gaskets so I can crack the intake open. DIY Intake Manifold Interior Cleaning - Toyota Nation Forum : Toyota Car and Truck Forums
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
