Old 08-25-2015, 06:51 PM   #29 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by cowmeat View Post
The EGR plate is pretty easy to clean, and I re-used the metal gasket with no issues on mine. More than likely the problem is the EGR valve itself, though. I got one for Ron Burgundy for like 55 bucks with a gasket and it works great, here's the link http://ecomodder.com/forum/showthrea...tml#post474729. That's a five minute fix, while the plate cleaning takes about an hour
You'll need one of those knuckles to be able to remove a couple of those bolts on the EGR plate btw, and keep a magnet handy for when you drop one into the bottom pan
I keep my RE92s at 60 psi with no ill effects, I kept the Maypops on the Festiva at 50 psi and never had an issue with them either.
I also run 60, but I don't recommend it to people as you lose A LOT of braking grip at 60 vs 45.
