Originally Posted by aardvarcus
I have mentioned on here before and despite having been jumped on for how dumb my idea is I will mention again it would be relatively simple to use the signal from the brake lights to control a duct or turn on a fan. The duct/fan could operate for a set time since the last time the brakes were pressed and then shut/turn off. Why duct, blow, or scoop air to the brakes all the time when it is only needed when they are being used?
That's a pretty good idea. But what ecomodder rides the brakes or uses them hard enough to need to cool them?
I do like this idea for the racecar I'd like to build. I think I will use this idea.
