Old 08-27-2015, 07:09 AM   #2 (permalink)
GhostWolfGT
GhostWolfGT's Avatar
Murturd - '95 Volkswagen Jetta GL
90 day: 33.15 mpg (US)
Saturd - '01 Saturn L200
2.slow - '04 Volkswagen Golf GL
90 day: 32.66 mpg (US)
Shouldn't be a spike above 14.x volts. Its regulated. Houses are not. So when there is a power surge it ruins electronics. The belt may squeal when the alt suddenly turns into an electromagnetic brake trying to top the battery off. I've done this at idle but never at higher RPMs. I have, however, had a short where my alt cut in and out without any adverse affects. Voltmeter bouncing from 14.3 to below 12 then back.
Also keep in mind that some cars won't run with the alt disconnected without other modifications. Test that before cutting wires and installing a switch.
Edit: Also, since I've never tried this maybe someone else can answer. Does it even help without having solar and deep cycle batteries? Seems to me like the extra load charging the battery back up would cancel out any benefits. Unless you disconnect on pulse and charge on glide. But I also believe this would prematurely destroy a regular battery.
