Old 08-27-2015, 11:55 AM   #12 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by adamj12b View Post
Here is a link to the PDF with all the serial commands.
http://adambrunette.com/firmware/cou...11b/README.pdf
Thanks for the link. I may have an older copy.
rtd_period 100 will get you a real time data stream from the controller every 100mS.
That does not work for me - no output.
If you running at least firmware 1.10, you can type config and get a list of all parameters. Once one is changed, you have to type save to write them to eeprom.
I will be working on the DC controller again this weekend, when I run out of things to do/that I can do with testing Paul's AC controller.
I'm sure I'll be posting more information
