Alright!
First part is in, and YES it is the coolant heater itself!
I have an amp meter, so i will try the glow plugs one by one out when the engine is ideling (14,5V) and see what Amps it draw, then count them all up
I think it will be arround 11-12Amps each, making it 500W @13,5V (lower Volt because the higher load on the alternator and losses in the cables)
I have had thouths about laying cables directly from the alternator to the coolant and oilpan heater. So the stock cabeling isn't touched. And lay a bridge from where i split the big diameter wire( where i seperate wires to the loads for heating) to the main stock fuse box. I readed somewhere that you can minimise electrical losses by upgrading the big wires,
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011
+ 10l/100km to 2017
5,516l/100km.
2017 without holiday:
5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
