Old 08-27-2015, 05:32 PM   #23 (permalink)
Longsnowsm
Longsnowsm's Avatar
Peaty - '03 Honda Insight
Jimmy - '07 GMC Canyon 2wd, Extended Cab, SL
Last night I cleaned the MAF, and the Throttle Body(TB), and replaced the plugs. MAF and TB looked pretty clean to me, but I scrubbed them up with some cleaner. The plugs however were a different story. A couple of the plugs showed some wear on the electrode so that I think was a needed fix. I didn't get an "Oh man, what a difference" feeling when done. I think it runs slightly smoother than before the cleaning and plugs replacement. Overall the process took 2 hours from beginning to end. Hopefully that will help things a little bit.
Next I have to button up the bed liner(still need to get the tail gate cover on it, and secure the sides with some screws) and get the tonneau cover on it. I will try to get that done this weekend. I had just tossed the bed liner in the back of the truck to get it out of the way of a garage project I have going on so I didn't get a chance to wrap up that install.
The cover is a roll up cover so I should be able to do some before and after comparison runs. I am curious to see how this truck behaves with the changes.
