Originally Posted by pearl62
Thanks again for the good info...
Didn't you mention that the oil pump can be reversed? Is there any negative impact to doing that? Is it hard to reverse the pump?
You're welcome!
The pump can only be reversed in the new design I am currently working on. I'll post some pics soon. This new design includes a completely new pump and completely new case.
I suppose a way around the pump issue would be to purchase a
reliable external pump - for example one designed for turbo oil scavenging - and carefully plumb it so the oil gallies are filled properly. BTW, Tilton engineering makes a good one.
- E*clipse
