Old 08-28-2015, 09:25 PM   #13 (permalink)
oil pan 4
On low beam the 9th gen suburban is wired so only the top head lights are on.
Then in high beam all 4 lights come on and go high beam.
If I could aim and terminate the LEDs like I wanted to I could run all 4 as low beam easy but with these 15 LEDs head lights I have pretty much ruled out using them as low beams. The only other problem with running all 4 low beams on is I might get pulled over for "using high beams in town", if they see all 4 lights on they are going to automatically assume "high beam".
I want to take these 15 LED lights put them in the high beam spot and level them at the horizon, aim the passenger side high beam a little off to the side so I can see deer, cows, horses on the side of the road and aim the drivers side almost strait ahead, favoring the left just a little.
Then I think I will put a post on dieselplace about them.
